my 99 3.8 is atomatic and im trying to put 5 speed manual in it i no the fourth gens use a ford bolt pattern inbetween the bell housing and trans case so in thery i can bolt up any trans a 5.0 mustang can the question is can i swap out the input shaft so the shaft length and splines match up? if so were can i get the input shaft and would i have to change the driven gear on the cluster shaft to match up with the new input shafts drive gear
need help
Re: need help
you should be able to get an input saft at a place like napa, or advance auto
the ford/gm transmissions might use the same case,so the bellhousing will bolt up, but the gear ratios will most likely be different.. just something to look out for.. i would try and get a t5 out of a v6 mustang if they used them.
Re: need help
Damn, no love for GM's T5?
http://forum.camarov6.com/showthread...hlight=mustang
http://forum.camarov6.com/showthread...ght=ford+trans
Seriously, is it really that bad?sigpic
Re: need help
i mean, im sure you can get it to work, you will just have to cut the center console apart and stuff
Re: need help
I'm pretty sure the bell housing is different on the Mustang T5s. In any case, the input and output shaft is different, the tailshaft is different, and I believe as mentioned above that the shifter is in a different location.
Since no one else has asked, why use a Mustang T5?? Why not a T5 from a Camaro or Firebird that is designed to fit your car??-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
Re: need help
