theres a whirring noise in direct relation with car speed, so the faster im going the louder the noise. it sounds like its comming from the differential. I just checked my differential fluid that I recently changed, and its definately full. its the zexel torsen. suggestions?
differential whirring noise
Re: differential whirring noise
I would say your pinion nut has back out. Thats what happend on mine.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Then it's either the pinion nut backing off or a bearing going bad. To check the nut, Jack the car up in the back, put jack stands under it, grab the drive shaft near the rear end yoke and see if it moves. Any movement is bad here.
Pinion bearings you need to disassemble the rear to check.sigpic
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
