What would be all i need to do to make my 3.4L Camaro into a 5-speed, will it be difficult, and how much you think it would cost me? Thanks
Automatic To 5-Speed Transmission Sway
Re: Automatic To 5-Speed Transmission Sway
a quick search :D:
-tranny /w bellhousing
-clutch, flywheel, preasure plate
-clutch master cylinder /w clutch reservior gm# 12555144
-slave cylinder /w throw out bearing
-pilot bearing
-shifter
-shift knob
-center console insert
-leather shift boot
-lower shift boot
-vss
-t-5 torque arm bracket/mount
-t5 cross member gm
-brake pedal
-clutch pedal assm
-M5 PCM
-lots of new bolts
-reverse lights switch leads
-clutch safty switch, pigtail leads
-tranny mount
edit: and yes, i think it would be hard... but i don't really know
yep, meatyshells did it and so have many others. im currently in the process of doing it myself.... its not as easy as an oil change, but it should be doable if your smart and take your time. ive been reading service manuals and diagrams for months =01999 v6 Camaro M5
Automatic to Manual converted
Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
!cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
once you have all the parts, it's cake :)
cost ~$1200 depending on what kind of parts you get
Originally posted by SolidSnakeWhat would be all i need to do to make my 3.4L Camaro into a 5-speed, will it be difficult, and how much you think it would cost me? Thanks
Originally posted by AceWaste of time and money. It is one of the most impractical things that you can do to your car.
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...4 weeks ago
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...4 weeks ago
