I was down at the walmart today and saw this transmisson treatment ......... it looked good ......... i was just wondering what it is (content) and anyone ever used it on their 4l60e? ...........
INFO:
Slick 50® High Mileage Automatic Transmission Treatment
The average age of a car on the road is 9.1 years. The automatic transmission fluids in high mileage vehicles can suffer from permanent viscosity loss and degradation in flowability. This out-of-spec transmission fluid can cause problems in the transmission such as wear, clunking, erratic or prolonged shifting, loss of torque, higher operating temperatures and automatic transmission fluid leaks. Most transmission treatments are added to try to fix a problem in a high mileage vehicle.
Slick 50® High Mileage Automatic Transmission Treatment is formulated to help cure the problems and to prevent them from reoccurring. The shear stable additive in Slick 50® High Mileage Automatic Transmission Treatment increases the viscosity of the transmission fluid back to the OEM spec and adds back vital compounds that are depleted over time. The restored transmission fluid will help improve shifting, protect against friction and heat, reduce leaking and maintain low temperature flowability. Slick 50® High Mileage Automatic Transmission Treatment comes with a 36,000 mile transmission limited warranty.
INFO:
- Helps to cure transmission problems of high mileage vehicles and prevent them from reoccurring
- Helps improve shifting by restoring the viscosity of the transmission fluid
- Helps protect against friction and heat
- Helps maintain the viscosity of the automatic transmission fluid
- Reduces leaking
- Helps maintain low temperature flowability
- Comes with a 36,000 mile transmission limited warranty
