broken torque converter? - FirebirdV6.com/CamaroV6.com Message Board
  • broken torque converter?
    What would be the symptoms of a broken torque converter, or a torque converter in the process of breaking? Today when i was driving i noticed my RPM's are higher than they should be at the higher speeds. Ex. normally at 2000 rpms on the highway i'm doing 69 MPH, today to get to 69 MPH i had to do about 2400 rpms.(my overdrive is still working) So i started experimenting accelerating in 3rd to see if my rpms dropped from the torque converter locking up and it didn't. Anyone have any thoughts?
    New Car: 2004 GTP Comp G (Test Vehicle) 13.936@99.32 <br />Mods: Cylinder Filter,No Mufflers, 3.3\" <br />Old Car: 2000 Formula 13.124 @ 106.01 with 2.73\'s<br />Other Car: 1993 Firebird 16.1@83
    anyone?
      perhaps your verter is not locking up..
      At a 70mph cruise.. if you give it gas do the rpm's softly go up a little as if the verter is unlocked or do they remain solid and slowly increase as your speed increases?
      Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
        <blockquote>quote:</font><hr>Originally posted by Magnus:
        <hr></blockquote>
        This is exactly how it is. My next question would be how bad is this for my vehicle, or is this only going to give me bad gas mileage at higher speeds?
          Well its not good.. you need to figure out WHY its not locking up.
          Do you have enough trans fluid?
          Try resetting the PCM.
            It may just be a bad solenoid (or circuit) ... you should have a tranny shop look at it before it turns into something expensive.
            You can achieve anything for which you are prepared to pay the price.<br /> --ATTILA THE HUN
              <hr></blockquote>
              It does have enough tranny fluid, and i reset the PCM and it still isn't locking up. I recently had my transmission casing replaced, is it possible the shop hooked up my torque converter wrong?
                Was it working when you left the shop?
                  it was working then, i'm just thinking maybe they did something that caused it to slowly go bad (not sure if it's possible, just a thought). I switched cars with a friend so he can bring it someplace to have it looked at.
