... is it easy to install??.. also where can i get the trans-go shift kit???
b&m shift improver installion?
if you have any background in mechanics, you can do it. I think all you have to do is drop the tranny pan, take out the valve body, Pull out the stock seperator plate, put kit back in its place and put everything back the way it was and thats it.
Just read to make sure you are putting in the correct stage...you want stage II for the street/strip.94 3.4L A4 white t-tops<br />moroso cai<br />3\"hi-flow pacestter exhaust<br />b&m shift kit<br />catco cat<br />01 T/A rear w/ 3.73\'s and posi<br />1 pc aluminum ds<br />blacked out signals
