4.10's are in... - FirebirdV6.com/CamaroV6.com Message Board
4.10's are in...
  • 4.10's are in...
    ..and WOW do they pull! :eek:
    Magnus helped me put his 4.10's in my car since he was riddin' of em. Going from open 3.08's to 3.42's wasn't nearly close to the jump from the 3.42's to the 4.10's! Off the line I squeal and hook pretty nicely and then the pull and slammin to the shift point.
    I can't wait to see how this compliments the cam and verter going on in the very near future. [img]graemlins/evilgrin.gif[/img]
    Then the GT and LT1 spankin' begins. Looks like I may keep Chitown representin' ;)
    [ August 18, 2003: Message edited by: epic ]</p>
    2002 NBM Firehawk #312 | <a href=\"http://hawk.visionsconnect.com\" target=\"_blank\">hawk.visionsconnect.com</a>
    Are you still running open or do you have lsd? It's a lot more difficult to squeel the tires with a posi as opposed to open.
    Are you going to deal with the speedo? Or let it remain off. Let me know if you find anything that works for 4.10 gears.
    94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
      Yep, still limited slip. Lighting up tires is a JOKE. Im going to run through tires so easily.
      I admit, the speedo is definately off. But with the amount of speed, it SO doesn't matter. Definately in the 14's no problem! Probably dropped ~.4 in the 1/4.
