T5 whine in 1st through 3rd - FirebirdV6.com/CamaroV6.com Message Board
  • T5 whine in 1st through 3rd
    Recently finished an engine rebuild on a 98 RS that had sat for about 2 years. Drained an re-filled the transmission with dex-3. It whines in 1st through 3rd only. Is this normal for the camaro T5? Google search got a lot more hits on mustang T5 issues, not much about Camaros.
    Thanks,
    David
    Re: T5 whine in 1st through 3rd
    Mustangs use the same WC T5 so you can use them as a example.
      Did you check what type of fluid it uses??? You have a auto or manual transmission?? Dex III is made for auto, most 5spd use gear oil
        Our T5's still uses DexIII.
          Can you say time for a rebuild? All T5's auto trans fluid.
