Just waiting for a little warmer weather to install it. Its from a 2000 T/A w/about 70K miles on it. Came with two new GM universal joints which have been installed. Man, that plastic the factory uses to hold the original U joints is a pain to deal with.
After the new joints went in, the shaft was cleaned up, as there was some under coat overspray on one side, and a few scratches. Wet sanded the shaft with 400 grit, then polished with a power buffer and some polishing compound until it had a nice satin finish. Left the aluminum end castings alone, just cleaned off dirt/oil/undercoat.
Made sure I didn't polish off any paint marks or the original UAW sticker w/part number (12564003). Also used 400 grit and machine oil to remove rust on the trans yoke spline shaft where it was exposed outside the tail shaft seal. Just wanted to be sure any residual rust would not damage the tail shaft seal. Also put the yoke on the wire wheel to remove rust, then gave it a a couple coats of black rustolium.
So here it is, ready to install. Not bad for $75 and an evenings work, huh?
