Which one would you get if you had the choice? I'm thinking 12 bolt because they are both pricing out about the same with a True Trac, and TA cover , and 33 spline axles.
12 bolt or 9"?
Re: 12 bolt or 9"?
If you were to have problems with snapping 10 bolts, I would look into a 12 bolt. Especially since you're running an auto, Steve. But I would avoid the Truetrac, if possible. They've been known to snap under those "sudden shock" situations that the Torsens are known for. Only difference is they are able to handle a little more torque than the stock units. You might be better off with a clutch-type Eaton in that situation.'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
Re: 12 bolt or 9"?
My fault , your correct it is a modified Eaton Posi with (800lb spring), I got them mixed up. My car def. hooks so I don't think a TrueTrac would be good then. Didn't know that about them. Thanks08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: 12 bolt or 9"?
9in all day. i love mine. a lot cheaper too since i built it. QP housing with moser 31 spline axles, detriot locker w/ 4.11s. Center section was a fresh rebuilt. in all it cost me 1700 shipped. show me a brand new 12 bolt that will b that cheap
87 Firebird RIP
96 Camaro RS RIP
94 Patriot Red 1LE Z28 - Sold
02 WS6 TA - Sold
Re: 12 bolt or 9"?
steve weren't you the one saying that you can use a 9" from an S10 or something on our cars, and you can pick them up for very cheap...all they need is a modification for the torque arm to work? I remember reading something about that and that you can get those for cheap....I thought it was pretty hard to break a 9" anyways?
Re: 12 bolt or 9"?
I think it was of a 95+ Ford Explorer have to have the TQ arm weled and LCA's welded on, I think that was it , it was a 8.5" rear, I'll probably end up with a 12 bolt , I'm just pricing them out right now, I'm just getting a list together and then will call a friend of my Dads who opened up a shop and see what he charges.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: 12 bolt or 9"?
PA racing has some shells you can look into as well, think they has some stuff listed for the 12 bolt for 500 or so...
Re: 12 bolt or 9"?
Theres alot of performance shops around town I think I will see if the mechanic can find what he needs and I'll let him put it together and install it. Won't be for sometime , maybe end of the year. I just want to see how the turbo goes and see what #'s it puts down. If I can get 400 WRHP I will be very happy, but for summer I don't think I could run that much maybe 7 PSI with the meth, but in winter 12-15 PSI should be fine with the meth. Still have to see if the auto will hold the power, if not I can use my dyno #'s to find a converter and go with a built tranny. Either way a 12 bolt or 9" is a good investment esp. since I'm keeping the car forever.LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: 12 bolt or 9"?
Originally posted by LETZRIDE View Poststeve weren't you the one saying that you can use a 9" from an S10 or something on our cars, and you can pick them up for very cheap...all they need is a modification for the torque arm to work? I remember reading something about that and that you can get those for cheap....I thought it was pretty hard to break a 9" anyways?
most drag racers running in the 8-9's use 9" rear ends, they are pretty tough, but i dont think a v6 camaro will make enough power to break a fully built 12 bolt unless it was abused.
Re: 12 bolt or 9"?
Originally posted by cam98aro View Posta 9" is a ford rear end, it would be pretty hard to find them off of s-10's since im sure there isnt many on them.
I would go with the lightest and cheapest one that will stand up to the job...if the 9" is cheaper and will more then stand up to 400 rwhp then why go with a 12 bolt and pay extra money if you never intend on putting down 700-800 rwhp? Put that extra money into something else.
Re: 12 bolt or 9"?
Originally posted by LETZRIDE View PostI wasn't sure if it was a 9" for sure, but I remember reading something about the rear end off a truck was supposed to be the equivalent of the 9" or 12 bolt something like that, and it was less then half the cost to pick one up and all it needed was fabbing.
the 10 bolt rears they put on the 4th gen fbodies are a hit or a miss, some people are using them putting down 450rwhp and beating the crap out of it and they hold up great, other peoples grandmas would be driving the car with 300hp and pull out from a stop sign and it breaks
me personally, i would just build whats already in there, im sure there are aftermarket differentials out there that are much stronger than what gm put in the factory, but thats just my opinion
Re: 12 bolt or 9"?
Originally posted by cam98aro View Posti was under the impression that the s-10's used the same rear end as we had.
Re: 12 bolt or 9"?
Originally posted by Choppers View PostI would look into a 9'. People over on ls1tech are breaking 12 bolts. Don't know how much power you are making though.
Originally posted by cam98aro View Postthe 10 bolt rears they put on the 4th gen fbodies are a hit or a miss, some people are using them putting down 450rwhp and beating the crap out of it and they hold up great, other peoples grandmas would be driving the car with 300hp and pull out from a stop sign and it breaks.
Originally posted by cam98aro View Postme personally, i would just build whats already in there, im sure there are aftermarket differentials out there that are much stronger than what gm put in the factory, but thats just my opinion.
Originally posted by LETZRIDE View PostEaton :D....I bought mine when my torsen took a dump at the track...Eatons held up nicely, they say they are supposed to be "Bullet proof"...clutch style differential and the gears that it does have inside are forged...'99 Camaro
'04 Saab 9-3 Aero
Re: 12 bolt or 9"?
Originally posted by pace2006 View PostMost of the people on tech breaking 12 bolts are those with an T56 and short gears (4.10s) or are either A4/T56 putting down numbers over 600whp.
That hit or miss effect is greatly influenced by how thick the gears in the differential are and what transmission is in front of it all. But I agree, chance can play a part in it.
I also think Steve should take this route. Stick with what you have. See how those 3.73s and the turbo treat that Torsen. If it starts making noises or blows, start looking into a 12 bolt or Dana S60 rear.
Bullet proof til it meets 4.10s and a T56. :P
I recently ran into a problem where when I drove my battery gauge showed low voltage. I compulsively replaced the battery and it was still doing the same...6 hours ago
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...6 days ago
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...3 weeks ago
by LETZRIDE
Building the Tom Henry RS
By: Hib Halverson
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
