hey guys i was lookin up some stuff and was just wonderin wat the difference was between the two. and wat they came in, would they be interchangeable on our firechikens. any info greatly appreciated
t5 or t5wc?
Re: t5 or t5wc?
You can use a T5 from 96-02 their all WC's, Borg was bought out by Tremec , so the later T5's will be Tremec and the 96' like yours will be Borg but both are WC's. I put a 00' T5 in my 96' when I had a T5, then went to a 02' 4L60E about 3-4 years which 96-02 A4's will work also if needed.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: t5 or t5wc?
This should help some of you with T5 tranny id and gear ratio Q's. http://www.britishv8.org/Articles/Bo...T5-ID-Tags.htm78 Lesabre Turbo Coupe w/85 GN SFI turbo induction, 200-4R OD, 3.73 posi(pictured in Sep. 99 Hot Rod Power Tour Article 87 Shelby Charger (under construction)reardrive conversion, SC3800, T-5, Independent rear. Estimated weight 2400 lbs.
Re: t5 or t5wc?
I believe yours is a WC tranny, but the WC trannies that are behind the V6 cars are still only rated at 230 ft/lbs. because of the gear ratios(tooth count on the input shaft) is the big difference.78 Lesabre Turbo Coupe w/85 GN SFI turbo induction, 200-4R OD, 3.73 posi(pictured in Sep. 99 Hot Rod Power Tour Article 87 Shelby Charger (under construction)reardrive conversion, SC3800, T-5, Independent rear. Estimated weight 2400 lbs.
Re: t5 or t5wc?
96-02 WC trannies in our cars are rated at 300 FTLBs and 300 TQ, thats about the power level when gears start breaking, esp. 3rd gear. I know I broke 3rd gear completely off. running around 300 hp and 330 TQ at th wheels.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
