air compressor - FirebirdV6.com/CamaroV6.com Message Board
air compressor
  • air compressor
    I was thinking about getting a small air compressor for my garage to make working on my cars easier at home. only problem- dont know anything about what compressors are good, good size, psi, hp, ect. so any help would be nice.
    like would ones like these be good?
    http://detroit.craigslist.org/tls/597604065.html
    http://detroit.craigslist.org/for/599536354.html
    or is it really not worth it unless you fork about a butt load of money for one?
    Re: air compressor
    What do you plan on running with it?
    <a href=\"http://www.cardomain.com/id/sac2165\" target=\"_blank\"> CAMAROS</a>
      Re: air compressor
      Most air tools run at 90psi so a 150psi with regulator is a start. What is most important is the scfm rating. You should get one that is at least 5scfm, or check the rating on your tools. The compressor MUST put out more than the tools require to keep the tank full and pressure higher than 90psi.
      Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
      Raven
        Re: air compressor
        how do you find the scfm rating on them?
          Re: air compressor
          Either on the tool, or in the manual that came with it.
          Raven
