bile from hangover - FirebirdV6.com/CamaroV6.com Message Board
bile from hangover
  • bile from hangover
    Where does the bile come from?
    Is it my stomach lining?
    Is it from my liver? no?
    Is this simply just a way for my body to tell me I'm over doing it?
    Maybe the bile is simply just a way to get me to throw up?
    Someone thinks that because alcohol dehydrates you, it takes away all
    the cerebro spinal fluid in your head...so thats why you get a headache. Your brain is literally rattling around, which could cause brain damage..
    Time for me to drink lots of water/gatorade, eat greasy foods and drink hot sauce.
    Re: bile from hangover
    caffeine which is a very strong vasoconstrictor which will narrow the swollen blood vessels in your head.
    bananas for potassium
    Drink some sort of fruit juice, it contains simple sugar fructose, which speeds up the metabolism of alcohol.
    Your body burns alcohol at a regular rate of roughly 30ml (1oz) an hour. Give it more time to burn that alchohol and less will reach your brain.
      looks like bile comes from the gall bladder, but I dont know why.
      I read that it is very dangerous to get throw up in your lungs
        i'm gonna go ahead and throw down a big ol' WTF
          It is very dangerous to get vomit in your lungs..........That's a no no, because then it can clog your lungs up causing you to take shorter breathes until it clogs the tub exiting your lungs all together and then your head will start to swell(this is your brain not getting enough oxygen) and then total shutdown of the central nervous system.
            Damn.
              I would also be scared the acidic vomit would burn through the lungs, making a hole, so now you got blood in your lungs / internal bleeding.
                you cant physically vomit INTO your lungs. what people do when they're drunk is vomit into their throat and then inhale the vomit. there's a physical barrior b/w the two tubes that doesnt allow you to vomit into your lungs. its the same barrior that prevents you from swallowing into your lungs.
                  its got to be hard to get vomit in you lungs... I have been drunk beyond no end vomiting and never gotten vomit in my lungs, I once saw a kid laying on his back vomit straight up like a fountain back down on to his face and not even choke on his vomit.
                  Either way, alcohol dehydrates you, which leads to the headache the next day, just get into the habit of after you drink alot you drink water or gatorade before you go to bed. Eventually you train yourself enough that even piss as drunk you still do it. Makes the next day alot better.
                  Its just basically your stomach fluids, your body is puking it up. Comes up different. weirdest one I have ever done was I puked up green slime/foam
                    This mechanism is called an epiglottis (yeah, HS bio). You can drown in your own vomit though by vomitting and THEN breathing it back it. It is how Bon Scott died. :(
                      Isn't bile one of the enzymes created in your body to break down food beyond the stomach?
                      Originally posted by SSMOWS6
                      i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
                      R.I.P. '07 Pats
                      Still... 18-1 > 1 and done
                        yes, which is why I dont understand why it comes up
                          being under the influence of narcotics or alcohol, your gag reflex wont work, and it will be inhaled with no resistance
                            Well how do you know its bile and not just stomach acid?
                            R.I.P. '07 Pats
                              its yellow and thick. Bile is described as being yellow or green (or mixture)
