Greetings all!! - FirebirdV6.com/CamaroV6.com Message Board
Greetings all!!
  • Greetings all!!
    Click image for larger version
ID:	1574882Click image for larger version
ID:	1574881 ​​​​Greetings from Alabama everyone! Proud to be in the group!
    Here's my ride.......2015 Camaro 1LT. I call it the Silver Surfer. Pretty basic, only additions are the rear spoiler, K&N CAI, tint and rear louver. Planning on a tune one day.
    Not sure how I manage to log into my bug testing account there..
    Anywho, welcome to the site! Any plans for her in 2020?
      Welcome to the site, yeah a tune will help a lot.
        Thanks for the welcome everyone. I haven't set in stone any upgrades so far. I've been thinking about the Trifecta tune from Phastek but the sticker price is pretty significant. I also seen a chip from Performance Chip Revamp (PCR) and it says it does a lot. I'd have to research it all though. Also thought about the Pedal Commander. I don't race or anything though.
        I have a few maintenance items to do. Swapping out the master cylinder reservoir, sensor done went bad. Should be an easy fix and bleed, luckily no Brembo calipers. Already go the new replacement reservoir and even came with cap!
          Do you have a tech 2 tool to bleed the brakes on it after?
            No. Just have the vacuum pump for the bleeder screws. I know it would be best to cycle the abs pump to change out all the old brake fluid. Seen on another forum site, that others done some work on their brake system but didn't worry about the abs pump. Figured if I protect the engine compartment and don't get too rough with the master cylinder, there would be little air to bleed out. Been trying to figure out the bleed screw size. One site said it was like 10 mm but it was on a SS.
              I did see a few folks say it was like $80 at the dealership to cycle the ABS.
                I believe you will need the shop to bleed the brakes with a tech 2. You can get away with not cycling the ABS unit as long as you are not introducing air into the master cylinder. I.e you are changing a caliper and you do it quickly enough that you do not allow the master cylinder to go dry. In this case you only have to bleed that particular line as no air would have been introduced anywhere else in the system.
                As soon as you have air in your master cylinder, your entire brake system will need to be bled.
                You may want to look into bench bleeding the master cylinder as well to help expedite the process.
                  Thanks! I gotten in touch with a family friend that works at a shop and has that repair info from Mitchell on demand. I did accomplish something today. That aggravating heatshield got silenced today by adding another clamp. Now it shouldn't be so embarrassing when riding slow by pedestrians
                  • Andy H
                    Hello everyone!
                    by Andy H
                  • 3.4 slow to go
                    hey there strangers!
                    by 3.4 slow to go
