went to go get my car inspected today and got a systems not ready rejection. the guy inspecting it said since my car is a 97 i am allowed to fail 2 out of the 11 readiness monitors. i failed catalyst, 02 sensor heater, and EGR system. if i can get one of those to go away, i can pass. any idea on what to do? My SES light is not on.. and i dont know what if anything i can do in hptuners to help me out. thanks guys!
failed inspection
Re: failed inspection
Does selecting "Error not reported" for those systems codes not help, or is that what made it fail? Only one I can think of off hand to fix is maybe the EGR. Just set the temperature so high, it never comes on.'99 Mountaineer AWD 5.0 - 4300K HID, Some Bolt-ons
'97 RS - HPTuner, Bolt-ons
'09 WRX - Aesthetic mods
If you have HP tuners go into DTC's and click on the ones you want deleted to no error reported and it will not come up on any scan they do. I have no cat, egr, and evap all deleted and it passes everytime, because all they do with mine is plug their scanner in to see if there are any codes.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by dmw319 View PostMy SES light is not on.. and i dont know what if anything i can do in hptuners to help me out.
Click the "Engine Diagnostics" tab, then in the new window that pops up, go over to the "DTC" button. Once there, find all the codes that are giving you problems, and in the "Error Mode" column, click down to "3 - No error reported," then reflash your PCM
Originally posted by ssms5411 View PostIf you have HP tuners go into DTC's and click on the ones you want deleted to no error reported and it will not come up on any scan they do. I have no cat, egr, and evap all deleted and it passes everytime, because all they do with mine is plug their scanner in to see if there are any codes.
thanks i will try this. i am pretty sure all the ones i have turned off already say 3-no error reported.. but oh well. ill double check.
thanks also smoke panther.Dave:
00 Supercharged Camaro - RIP
97 Turbo Camaro - Sold
doesnt just driving around fix that problem? have you had the battery dissconnected recently? or the pcm flashed?
i went to get my car inspected and my pcm wasnt "ready" because i was working on the car that night with the battery dissconnected. told me to come back after i drive around for ~50 miles. Came back and passedLast edited by Meatyshells; 06-13-2008, 10:45 PM.
Originally posted by insaneABOT View PostI'm surprised that you passed the under hood inspection. Maybe it's because your in Carolina. The smog inspections maybe different from California standards.
I Can't even pass visual. I have to look around for a tech that would.
Cali does suck my car is all stock and still I could not pass the inspection guy told me that the car was to rich at idle and that would not let my car pass the smog inspection. So if I ever want to go turbo I know for a fact I'm never going to pass smog. Unless I bribe the guy so he can pass it.Last edited by insaneABOT; 06-14-2008, 10:07 AM.
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...11 hours ago
by ssms5411Well my iPhone 11 Pro Max took a dump, it’s in a boot up loop, will try and get it fixed and give it to my mom. So I got a new iPhone 15 pro max, everything...1 week ago
by ssms5411So I’m still leaking coolant, I think it’s my front cover, going to double check when it’s alittle warmer, got the Zzp extra thick timing cover...2 weeks ago
by transamtom1Local car on a small lot just over 100k mikes(178,000 kms)
Silver with grey leather and black top 3.8L for $5400 cdn or $3975 usd as is....3 weeks ago
