Originally posted by ssms5411
View Post
Engine overheated tonight
Yes, Mike, I'm going to do the most obvious ones first. It's been a long time since I've top off my coolant and replaced the stat. I'll also replace the CTS.
I'll try and see about jumping those terminals if these don't work.
Leave a comment:
Originally posted by 2.8 Bird View PostWell, I looked at it again. The fans do come on when I turn on the AC. So that means no problem on the low end and I guess relay #1 is good then.
it took about 13 mins for for the temp to reach 210*. The fans did not turn on. I gave it a couple more mins and it reached 215 and still no fans. So I guess this is definitely my problem.
I'm going to pepboys and see if I could rent their ohm meter and play around with those relays. First time I've done this.
If the relays were installed and it worked than your culprit is not likely the relays.
I would be looking for proper coolant level, making sure the system was bled properly, looking at possible belt slip that may cause the wp not to work as it should? A stuck or faulty thermostat?
Have all of those been ruled out?
Leave a comment:
Stock fan settings is like 220 temp for low and 230-235 for high, so I would let it warm up some more.
Leave a comment:
Leave a comment:
Thanks guys. I didn't get a chance to check it out today. I got too busy. Hopefully tomorrow.
I would really appreciate it Mike.
Leave a comment:
This is the wiring diagram for the fan relays: http://shbox.com/1/fan_schematic_1995.jpg
Essentially the relay is a switch. You have to close the switch to bypass it. I will need to take a look under my hood if I get a chance tommorrow and pull my relays to be able to tell you exactly how to do it. When I did it I just took a wire and pushed it in two ports where I had removed the relay to close the circuit.
You could try testing the relay itself by pulling it and jumping power to it from the battery. You will here it snap closed when you apply power to it. This will tell you if you have a bad relay. The diagram for the relays is located on the side of each relay
Leave a comment:
Originally posted by LETZRIDE View PostHave you tried jumping the relays?
I wonder if the coolant you smelt was overflow?
how do I jump those relays. I think that there are 3 relays to this.
tomorrow I'll check it out and see if the temp rises fast at idling. I've already ordered the stat from intense racing.
Leave a comment:
Originally posted by ssms5411 View PostTurn the A/C on, and see if the fans kick on. Should come on low at least , for high I don't know, I use my fan switch to test mine or Hptuners.
How do I set it up for a fan switch. The previous owner of the fiero I used to own did that.
Leave a comment:
Leave a comment:
- 1 like
Leave a comment:
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...3 weeks ago
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...3 weeks ago
Leave a comment:
