Ok guys what ALL would I need to add 3.42's to my car. For the cheapest price. Thanks
Adding 3.42's
Easiest way to do it would be go to a salvage yard, and grab the entire rear-end from a Y87 camaro. this will give you 3.42's and LSD. Changing the gears themselves is a very precise process, and can get expensive in labor.1997 Y87 Camaro with a motor and some stuff.
or find a used 98+ f-body with the y-87 pkg. so you don't have to spend all that money on installing a new rearend. If all you want is 3.42 w/ lsd/posi, save your cash for a new moser 12-bolt setup with abs, disk brakes, 3.42 w/lsd for about $3000= installed.2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
Would I be able to take a rear end from a junkyard F-body with the Y-87 package and put it in my car since it has the 3.4 and Y-87's were in 3.8's? Or better put, can this be done fairly easily and cheap, or is it a big hassel? Thanks for any help! :D\'95 Med. Quasar Blue Camaro 3.4 A4<br />Bunch o\' mods<br /><b>10.18 @ 67.60 mph 2.22 60 ft (1/8 mile)</b> <br /><br />-1986 Camaro with a carbed 350<br /><b>8.53 @ 81.45mph 1.8 60\'</b><br />AIM CamaroL32
Umm, its not that bad to change your gears. I got a ring and pinion set brand new off ebay for $80, bought the Zexel-Torsen LSD from slponline.com for $99, handed the mechanic $300 for the install. That comes to $480 for complete gear swap, quite a bit cheaper than a new $3000 rearend and better than $200 for a junkyard rearend and $250 for the install. Just my .02C. Boney<br />1997 Firebird 3.8L V6<br />---------------------<br />Modifications:<br /> <br /> SLP Cold Air Induction, Ported/Polished Throttle Body, Carsound 3\" High Flow Cat, Sweet Thunder 24\" Chambered Muffler, Removed Rear Exhaust Section, Custom Fan Switch, 35th Anniv. Silver Stripes, Old T/A-Style Silver Sail Birds
<blockquote>quote:</font><hr>Originally posted by dstrbd1:
actually the install was easy for me except for my two little hold ups. backlash and everything came out fine without any adjustments after the fact.<hr></blockquote>
Dude, so what kinda of difference did you notice w/ the new gears? I'm dying to get my end swapped.
Nevermind, i just saw your other post. Enjoy em, and good luck @ kennedal [img]graemlins/thumbsup.gif[/img]
[ February 18, 2002: Message edited by: Blac Drop Top ]</p>2002 Electron Blue Corvette<br />1999 Black Mazda Truck<p>AKA: Night Rider
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...2 weeks ago
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...2 weeks ago
