Looks great! When are you planning to install it? And, how much are you able to safely port that lower out?
aussie intake
the install's gonna be a ways off. Im planning on pulling the engine and tranny for a full rebuild with flat top pistons, cam and intense heads. Getting the time for this between work and taking care of my kid is sketchy at best. As far as porting goes, im gonna gasket match the ports at the head surface. the runners and plenum im just going to mirror polish the inside. I want air velocity more than air flow for this build, so I don't want to open up the runners too much, just make then smooth as glass so theres no restriction in the air path.
So I removed the stock manifold to fit the aussie one. As you can see from the pics the manifold fits in the car without any modification. The problem is the huge dbw f-body throttle body. In any position it hits the underside of the cowl and is about an inch too low for the throttle bore to line up with the plenum inlet. So doesn't look like I can avoid cutting the cowl.
Well that sucks, but it does look pretty cool in there. How much of the cowl needs to go so you can fit the TB?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by mdiesel View PostSo I removed the stock manifold to fit the aussie one. As you can see from the pics the manifold fits in the car without any modification. The problem is the huge dbw f-body throttle body. In any position it hits the underside of the cowl and is about an inch too low for the throttle bore to line up with the plenum inlet. So doesn't look like I can avoid cutting the cowl.
I believe he talked about lowering the motor a little bit with a spacer somewhere in that thread if I am not mistaken
I found this on ebay austrailia, it'll bolt right up to the manifold, turn the throttle forwards, im hoping it'll get it forwards enough to get the TB just past the front lip of the cowl. I have a cowl induction hood, so once its past that cowl lip hood clearance isn't an issue. if this works my woes are solved.
Looks clean! How much longer until she's running?
no new pics for today, but after much trial and error it seams no combination of fittings will allow me to make the connection from the manifold to the belt tensioner for the heater core . I could order an aussie tensioner, upper and lower heat pipes ( yea theirs are separate from the tensioner ) but none of the ebay junkyards have all the parts from one place so id have to pay 3 times shipping. so, Im just gonna plug the openings at the manifold and water pump and delete the heater core all together. I figure I live in Florida I don't need heat... especially on a car that im only gonna be driving for fun on weekends.
Yeah, no need for heat, I won’t have heat or A/C when the turbo goes on.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...6 hours ago
by ssms5411Well my iPhone 11 Pro Max took a dump, it’s in a boot up loop, will try and get it fixed and give it to my mom. So I got a new iPhone 15 pro max, everything...1 week ago
by ssms5411So I’m still leaking coolant, I think it’s my front cover, going to double check when it’s alittle warmer, got the Zzp extra thick timing cover...2 weeks ago
by transamtom1Local car on a small lot just over 100k mikes(178,000 kms)
Silver with grey leather and black top 3.8L for $5400 cdn or $3975 usd as is....3 weeks ago
