Ignition wires with pace setters? - FirebirdV6.com/CamaroV6.com Message Board
  • Ignition wires with pace setters?
    Okay so the pace setters are on order and supposed to arrive tuesday. However, I dont know which wires to use so I bought the Accel 8 mm wires. Anyone know which wires to use with the headers?
    Re: Ignition wires with pace setters?
    You can use 90 degree or straight boot, I use straight boot with boot protectors and they work great.
      Okay thanks man, that kind of puts me at ease. The Accel wires were freakin expensive for ignition wires but they are 8mm so I will try them. Are boot protectors necessary? Accel says its good up to 650 Degrees?
      On a separate note, I am trying out the E3 diamond fire plugs for the car.
        I have just cheap-o plug wires. Straight boot, no protectors. I burned through a wire once on the headers, but then I went through the garage and just mixed and matched lengths I had lying around until everything was routed well clear of any heat. Just have to play with it :P
          I have a build a Mallory build a set for a V8 with 90 degree boots. Works great and ends up cheaper than anything else.
            So do you guys think the straight boots will work or no?
              I use straight boots with my pacesetters but I would recommend boot protectors, I'm running 10.2 mm wires.
                I have the msd 90's, I bet 2 and 3 would be a pain to get a straight boot on there without touching the header.
                  I used 90* on my engine with headers
                  http://www.bowtiev6.com/
                  • Andy H
                    Hello everyone!
                    by Andy H
                  • 3.4 slow to go
                    hey there strangers!
                    by 3.4 slow to go
