If you have a bolt of unknown thread size you can find the size by trying different nuts at Ace - or similar store.
So what happened to the balance shaft drive gear bolt? You said you got it out.
Oddball balancer?
I got my bolts and puller from ZZPerformance , used it twice now, little expensive but pays off.
Leave a comment:
Originally posted by Dog Fodda View Post
Appreciate the help, but 3/16" is smaller than 1/4"
Take the bolt to Ace and try nuts.
Leave a comment:
Some of the newer pullers don’t have the right size bolts in it to fit the pulley. I remember I had to go back to my old kit to find the correct bolts.
I can’t remember the size bolts so it may mean a trip to lowes to buy a few different sizes to get the right pitch/threads.
I do remember it being odd sized for sure!
Leave a comment:
Oddball balancer?
I have a 1999 3.8 with 67k miles. Im removing the timing cover to replace the chain. Ive already got the balancer bolt out, and now need to pull the balancer.
The thing is, i dont have the special puller so im using the normal puller. Everywhere on the net it says to use 6mm × 1.0 or 1/4 - 28 bolts. Ive tried both and they are too small.
It looks like they are m8 or 5/16 fine because a 5/16 course almost threads in.
Is this a special limited edition canadian balancer, or is there a vast balancer bolt conspiracy? Is this a third variant bolt size thats common? I dont want to damage the threads.Tags: None
by ssms5411Just ordered some under dash lighting from Amazon. Hopefully get it next week and install it. Here’s the link:
LEDGlow...2 days ago -
by 2.8 BirdBelieve it or not I've had these headers since 2006. Back then the shop that going to do it was charging me 320 dollars. He advised me to hold it because...2 days ago
by 2.8 BirdThis car is amazing. It's hard to believe it's a production car that doesn't need any modifications.
0 to 60 in 1.6 seconds
Quarter...1 week ago -
by mdieselso my engine was originally an L36. upon disassembly i found the crank and rods were out of spec and needed to be replaced. I have a new crank, and i...2 weeks ago
by mdieselnot sure what some of you guys with 3.8l's and 4l60e trannys are doing for converters. None of the typical converters that fit this tranny and v8 models...2 weeks ago
Leave a comment:
