Update: Just pulled an L32 out of 2006 Gran Prix (supercharger and all) with 85k on it for 800$. Literally the only one on Long Island we could find and with low mileage, I want the lower compression to run more boost safely.
Turbo 3.8 Spun bearing failure
Yeah no E85 close here. Would be even sweet to run 93 too. Only 91 here.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Turbovert01 View Post
I wanted to run E85 actually, but its my daily and E85 is hard to come by around here, will start with 93 and may switch over one day.
Especially being a turbo car the benefits are way bigger than NA cars
Originally posted by LETZRIDE View Post
Have you looked into Meth? I want to run meth even on my NA car. Aside from the cooling benefits pure meth will give you an octane rating of 116 when sprayed with the use of 91 octane in the tank.
Looks good, and you can sell the left over parts.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
That’s a good price for the 5th gen blowers.
Meth is a good thing to look into- even if you don’t tune the car on edge and use it for safety. You can have it only spray at WOT, so it lasts a long time before having to refill. A lot of guys actually hook it up to the windshield washer fluid and use the washer fluid which is 40% meth in their cars.
You could actually not use a intercooler too if you wanted as meth cools the intake charge quite a bit
Always run a intercooler with a turbo , meth is just a added feature to run more boost with no KR. You'll burn a piston with no intercooler.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Hey quick question guys I can’t find a solid answer online, can I use the L36 flexplate on my L32 block? Some people say it’s fine some say it will spin a bearing.
UPDATE: This is a flexplate not flywheel so I’m pretty sure we can, ZZP says so because it’s internally balancedLast edited by Turbovert01; 06-06-2019, 06:41 PM.
Originally posted by SHADOWII View Post
Have you torn down the L32 block to determine the cause of the failure? Was it actually a spun bearing and what bearing failed? In my experience it is usually a blocked oil passage or pump failing or failed. Which could be from something as simple as a poor choice in oil filters. Many oil filters have allowed trash to pass thru. Napa or WIX(I think WIX supplies NAPA?) have proven to be the most reliable. It was discussed in the buick community and that was the conclusion.
Originally posted by Turbovert01 View PostHey quick question guys I can’t find a solid answer online, can I use the L36 flexplate on my L32 block? Some people say it’s fine some say it will spin a bearing.
UPDATE: This is a flexplate not flywheel so I’m pretty sure we can, ZZP says so because it’s internally balanced08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...9 hours ago
by ssms5411Well my iPhone 11 Pro Max took a dump, it’s in a boot up loop, will try and get it fixed and give it to my mom. So I got a new iPhone 15 pro max, everything...1 week ago
by ssms5411So I’m still leaking coolant, I think it’s my front cover, going to double check when it’s alittle warmer, got the Zzp extra thick timing cover...2 weeks ago
by transamtom1Local car on a small lot just over 100k mikes(178,000 kms)
Silver with grey leather and black top 3.8L for $5400 cdn or $3975 usd as is....3 weeks ago
