My turbo build - FirebirdV6.com/CamaroV6.com Message Board
My turbo build
  • Finally got my money back for the 315 tires, called my credit card company and they refunded it. Waited over 3 weeks for the refund. 2 months total dealing with them. The company MBgram would not recommend.
    • Installing a digital boost gauge this week, my other one is too hard to read when driving. Should be able to see A/F gauge and boost in one glance. Will post pics when done.
      • Got it in, not reading vacuum very well, was at 15-16 vac on the other gauge, showing 9-10 on the digital. I’ll take it out later after the oil change see what boost it shows. Click image for larger version
        • Got a Glow Shift digital vac/boost gauge, seems to be reading alright, vac is 19/20 , will find out if the boost is correct this weekend if the weather is good. I have 10 different colors so I can lighten it up when driving. Just shows you don’t buy cheap stuff.lol
          Click image for larger version  Name:	E884671E-C3E0-427F-B5B1-BF7BCCED027A.jpeg Size:	2.45 MB ID:	1578504
          • Rainy weekend so far, so no tuning. Might be able to get to it Thursday or next weekend. Temperature wise it’s perfect out. Just rainy.
            • It looks good. It looks very clean in your car.
              • Originally posted by 2.8 Bird View Post
                Thanks Edgar, yeah forgot to use the filter with the old one , finally found it after I got the Glow Shift one, so it probably works alright, I have about 3-4 boost gauges just sitting, might just sell them.
                • Picked up a new Walbro 255 high flow fuel pump, GSS342. My current Walbro 255 high flow is over 20 years old so eventually will go out. Never had any problems with it, can’t complain.
                  • Does yours make that high pitch sound? That's how my old one failed. The current one is starting to make that noise now.
                    • No just thought I’d pick one up, still working great, took me awhile to find it. The normal Walbro 255 is GSS340, and the high pressure 255 is GSS342. Are you running a Walbro 255? If you’re running the Powerdyne you should look into the high pressure one their suppose to be for boosted vehicles. That’s why I run the high pressure pump. When you turn the key in the on position it’s supposed the prime up , is that what you’re talking about Edgar?
                      • Wow...I didn't even know there's 2 types. I don't even know what I have. I probably won't run a high pressure one because I haven't upgraded my injectors.
                        • I ran it on stock injectors for awhile, the high pressure just runs better, with higher flow pressure the pump doesn’t bleed off in the upper rpm’s and Wot, if you’re running the supercharger you’ll want the higher flow pump. Your fuel pressure is still controlled by your FPR.
                          • Edgar sent you a pm.
                            • Thanks Steve. The messaging system won't let me send a message to you, but I'll be interested in getting that pump from you. Maybe after the holidays
                              • Yeah that’s fine, Yeah I had trouble too, just let me know.
                                  Had to get another phone
                                  Well my iPhone 11 Pro Max took a dump, it’s in a boot up loop, will try and get it fixed and give it to my mom. So I got a new iPhone 15 pro max, everything...
                                  Leaking front cover
                                  So I’m still leaking coolant, I think it’s my front cover, going to double check when it’s alittle warmer, got the Zzp extra thick timing cover...
                                • transamtom1
                                  Went to look at 2002 V6 Firebird Vert.
                                  by transamtom1
                                  Local car on a small lot just over 100k mikes(178,000 kms)
                                  Silver with grey leather and black top 3.8L for $5400 cdn or $3975 usd as is....
