My turbo build - FirebirdV6.com/CamaroV6.com Message Board
My turbo build
  • Originally posted by 2.8 Bird View Post
    I hope it doesn't ruin the nice aesthetic of your car.
    Need it to keep the rain and snow until next year, don’t really care what it looks like. Car needs paint pretty bad anyways.
    • Click image for larger version  Name:	E97C7E77-4817-4975-B71F-9F299273600B.jpeg Size:	2.14 MB ID:	1577970 Click image for larger version  Name:	1E7235C2-3B3C-44D7-9084-07A8D0467632.jpeg Size:	2.21 MB ID:	1577965 Got my tires and down pipe routed to the exhaust today, really quiet cruising and at idle. Sounds really good through the 3” cutout. Only stuff I need to do is relocate the battery, get the new hood and then have it painted or wrapped. The only thing that I need to do is wrap the down pipe to where the Y use to be. Click image for larger version  Name:	AF57AF6F-11C6-4ECA-8A26-15F84C269267.jpeg Size:	1.94 MB ID:	1577967 Click image for larger version  Name:	E97C7E77-4817-4975-B71F-9F299273600B.jpeg Size:	2.14 MB ID:	1577963
      • New tires feel good, 7 years on the old ones, they were cracked and dry rotted. Also my part throttle tune is really good, cruised up the mountain at 50 mph with no problem, temp got to 204 degrees with the fan switch on.
        • Ordered a new 38mm wastegate dump tube, other ones wouldn’t fit , too tight of space, So ordered flexible tube.
          https://www.ebay.com/itm/352941640487
          • Got my down pipe wrapped, it’s being a pain putting it back on will try tomorrow and install the wastegate dump.
            • Got it done, had trouble with the wastegate dump tube, going to have to modify it. Need to finish tunning, swap transmission pan, relocate the battery, then I’ll be done.
              • Cool, sounds like it's coming along! I admire your tenacity. Lol. I need to get back to working on my engine soon.
                • Originally posted by Namrepus28 View Post
                  Thanks, it’s something to do.
                  • Got the wastegate dump tube on, took about a inch and a half out of the bend and welded it back up. Dumps out the bottom now which should keep things cooler. No pics, maybe next time I jack it up.
                    • I think I’m going to do the battery relocation tomorrow. Also install the new coolant res. and do the air filter from the turbo to fender well.
                      • Got the battery moved, started right up. Need to clean up the wires and stuff then do the air filter and coolant res. hopefully finish tomorrow. Will post pics, back is killing me so just doing that took all day with many breaks in between.
                        • Finished for now, back is killing me. Click image for larger version
ID:	1578037 Click image for larger version
ID:	1578038 Click image for larger version
                          • Going to redo the turbo inlet, some say the tube might collapse under boost. Sent a email to Intense, replied it probably hold, well I’m not risking a $2400 turbo to probably, so ordered 4” exhaust pipping and silicone connectors. Should get them next week.
                            • Very nice Steve. Looks like everything is coming along nicely.
                                Thanks Edgar
                                • Andy H
                                  Hello everyone!
                                  by Andy H
                                • 3.4 slow to go
                                  hey there strangers!
                                  by 3.4 slow to go
