Originally posted by 2.8 Bird
View Post
My turbo build
Got my tires and down pipe routed to the exhaust today, really quiet cruising and at idle. Sounds really good through the 3” cutout. Only stuff I need to do is relocate the battery, get the new hood and then have it painted or wrapped. The only thing that I need to do is wrap the down pipe to where the Y use to be.Last edited by ssms5411; 05-06-2022, 05:54 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
New tires feel good, 7 years on the old ones, they were cracked and dry rotted. Also my part throttle tune is really good, cruised up the mountain at 50 mph with no problem, temp got to 204 degrees with the fan switch on.Last edited by ssms5411; 05-07-2022, 06:38 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Ordered a new 38mm wastegate dump tube, other ones wouldn’t fit , too tight of space, So ordered flexible tube.
https://www.ebay.com/itm/352941640487Last edited by ssms5411; 05-08-2022, 08:43 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got my down pipe wrapped, it’s being a pain putting it back on will try tomorrow and install the wastegate dump.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got it done, had trouble with the wastegate dump tube, going to have to modify it. Need to finish tunning, swap transmission pan, relocate the battery, then I’ll be done.Last edited by ssms5411; 05-15-2022, 03:27 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Namrepus28 View PostCool, sounds like it's coming along! I admire your tenacity. Lol. I need to get back to working on my engine soon.
Got the wastegate dump tube on, took about a inch and a half out of the bend and welded it back up. Dumps out the bottom now which should keep things cooler. No pics, maybe next time I jack it up.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I think I’m going to do the battery relocation tomorrow. Also install the new coolant res. and do the air filter from the turbo to fender well.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got the battery moved, started right up. Need to clean up the wires and stuff then do the air filter and coolant res. hopefully finish tomorrow. Will post pics, back is killing me so just doing that took all day with many breaks in between.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Going to redo the turbo inlet, some say the tube might collapse under boost. Sent a email to Intense, replied it probably hold, well I’m not risking a $2400 turbo to probably, so ordered 4” exhaust pipping and silicone connectors. Should get them next week.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by 2.8 Bird View PostVery nice Steve. Looks like everything is coming along nicely.
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...12 hours ago
by ssms5411Well my iPhone 11 Pro Max took a dump, it’s in a boot up loop, will try and get it fixed and give it to my mom. So I got a new iPhone 15 pro max, everything...1 week ago
by ssms5411So I’m still leaking coolant, I think it’s my front cover, going to double check when it’s alittle warmer, got the Zzp extra thick timing cover...2 weeks ago
by transamtom1Local car on a small lot just over 100k mikes(178,000 kms)
Silver with grey leather and black top 3.8L for $5400 cdn or $3975 usd as is....3 weeks ago
