Yes, I heard about mag being insufficient. Does asp sale anything for it. Yes, you're right. 50 bucks increase and not 100. Have you thought about wrapping them instead of spraying them to lower the engine bay temp.
EBay turbo kit
Originally posted by 2.8 Bird View PostYes, I heard about mag being insufficient. Does asp sale anything for it. Yes, you're right. 50 bucks increase and not 100. Have you thought about wrapping them instead of spraying them to lower the engine bay temp.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Just read up on wrapping them and thats what ill end up doing, didn't know too much about wrapping them, so ill spray them first then wrap them.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
So I got 1 side of the headers painted used 2 spray cans of 2000 degree clear heat coating, ordered 2 more cans to do the other side and also ordered 50ft of DEI heat wrap, got about $200 in materials so far, better than $900 just getting them coated at Jethot, will post some pics once I get them wrapped.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
Heres a pic of the headers wrapped. Never done it before so i hope they do good.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
I'm going to try and get this kit on, but its so damm hot out Im going to do a little at a time.First I need my double roller timing chain done and my oil sender cover replaced and need to delete the A/C too. Will see how much I can do. These 100+ degree temps are a killer, plus no garage , just a carport.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
Originally posted by 2.8 Bird View PostNot bad Steve. Too bad it has to be covered with a wrap. It covers that nice metal.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
One bad thing, to get my breather on I had to take off the STB, wont fit with the breather, but I run a 35mm front sway so probably wont notice it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by 2.8 Bird View PostSo are installing it now Steve or just mocking it up.Last edited by ssms5411; 06-24-2018, 05:56 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
According to their full kit , it doesn't delete the A/C, so will see when I go to install it08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
Got the breather on and blocked the throttle body again, going to start the timing chain and oil neck next, if I can beat the heat.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
Nah not a catch can the breather works good, zzp has a lower profile breather that I might get. Ill see how the temps are before I do water injection I don't drive it that much08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...10 hours ago
by ssms5411Well my iPhone 11 Pro Max took a dump, it’s in a boot up loop, will try and get it fixed and give it to my mom. So I got a new iPhone 15 pro max, everything...1 week ago
by ssms5411So I’m still leaking coolant, I think it’s my front cover, going to double check when it’s alittle warmer, got the Zzp extra thick timing cover...2 weeks ago
by transamtom1Local car on a small lot just over 100k mikes(178,000 kms)
Silver with grey leather and black top 3.8L for $5400 cdn or $3975 usd as is....3 weeks ago
