EBay turbo kit - FirebirdV6.com/CamaroV6.com Message Board
EBay turbo kit
  • EBay turbo kit
    https://m.ebay.com/sch/i.html?_from=...turbo+kit+3800
    Thouhts on this...
    I don't know about this one,lol Would have to see the hotside a little more closer. Everything else I would junk, even the tiny intercooler.
      And whats up with the fan in the pic? Are you suppose to hook it up to something .lol
        I think im going to buy the one below it for $575, its the hot side , but ill scrap the turbo and use a t4 for my gt35r. Its about $500 for a t4 exhaust side for my turbo or ill see about using a t3/t4 adapter. Nice find Edgar
          I was thinking the same thing too. The hot side looks good, but AC has to be deleted, which is hard to do since I literally live in the desert.
          the turbo and the cold side doesn't look good.
            I don't think the A/C needs to be deleted on this one, just run a open down pipe, thats what Im thinking. I did it with my under K kit.
              Just found a t3 to t4 adapter on ebay, only 1/2" thick , should have enough clearance.
                Bought it, ill let you know how it is when i get it, ill take some pics and compare turbos.
                  Oh no kidding. Did you buy the hot side only along with the turbo. Yes, please post some pics.
                    Yes bought the hotside, will post pics. I think I know whos selling the kits, but ill wait to see if they come back to this site. Cartunning just lost a sale btw, if they would of gotten back with me through my emails, sent them 3 , I would have gotten their kit.
                      You might be right about the A/C , Lookimg at the 3rd pic where they show the pic of the car, the turbo is mighty close to the A/C canister, i just emailed them to find out. The a/c line has already been modified on mine so its out of the way. Will see.
                        I'm sure it going to be a clean set up. Can't wait to see it in your camaro.
                          Hope so, they said my gt35r should work but their checking on the A/C, either way ill install it. Got my turbo tub out and went through everything, forgot how much stuff I had. Going to run the 10lb spring in the Tial wastegate , and use my boost controller to get it to 15lbs of boost. So will see, its not going on until I get the car painted next year. But ill post pics of their kit.
                            15psi is alot of boost. That easily over 400rwhp.
                              Its not a daily driver so it should be fine, ill start with 10psi and go from there.
                                Had to get another phone
                                Well my iPhone 11 Pro Max took a dump, it’s in a boot up loop, will try and get it fixed and give it to my mom. So I got a new iPhone 15 pro max, everything...
                                Leaking front cover
                                So I’m still leaking coolant, I think it’s my front cover, going to double check when it’s alittle warmer, got the Zzp extra thick timing cover...
                              • transamtom1
                                Went to look at 2002 V6 Firebird Vert.
                                by transamtom1
                                Local car on a small lot just over 100k mikes(178,000 kms)
                                Silver with grey leather and black top 3.8L for $5400 cdn or $3975 usd as is....
