Rear End Noise Update - FirebirdV6.com/CamaroV6.com Message Board
  • Rear End Noise Update
    Well the "thumping" noise went away the day I was putting the car on the flat bed tow truck to take to the local dealer.
    They inspected the underside and found nothing.
    So - opened up the diff and inspected - nothing - so installed the 97 V8 axles (one year only) w/ 20mm extended lugs, new outer bearings/seals, new C-clips, and GM 80W-90 gear oil.
    Also installed new 98+ 1LE Trans mount and ES Torque Arm bushing.
    Changed Trans lubricant to GM 88861800 "Manual Transmission and Transfer Case Fluid" - which was changed from Dexron III ATF by GM Bulletin 04-07-30-037D in 2007.
    Also installed new Overflow Coolant/Battery Tray and new Diehard battery.
    Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
    Raven
    Good to hear Robert.
      Weird how some problems fix themselves sometimes... always right before you bring it in!
        How’s your car running now Robert?
          Great - particularly the manual trans with the new fluid - shifts really nice. Anyone with a manual should get rid of the Dexron III ATF and use the new GM manual trans fluid.
          Raven
          • Andy H
            Hello everyone!
            by Andy H
          • 3.4 slow to go
            hey there strangers!
            by 3.4 slow to go
