Anyone have this fail? What kind of noise does it make? Could you "blow it out" driving into a depression in the road, compressing the rear suspension, and significantly changing the shaft angle?
Driveshaft Universal Joint
Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
RavenTags: None
Yours on your car Robert? Haven’t had one fail on mine so don’t know.Last edited by ssms5411; 04-06-2020, 08:44 AM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Yes - could be the torque arm bushing? It's speed related and appears to be a vibration?Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
Raven
When my Camaro one went (I can't remember if I had 2 piece or 1 piece at the time) it made a loud humming sound with vibration - it almost sounded as if the brakes were rubbing. When the one on my Jeep went it made more of a squealing sound.
I don't believe it can go out from a large bump.
Have you gotten under the car and checked the joint for play? Grab the driveshaft by the U-joint and try to move it side to side and up and down. If you can move it the U-joint needs replacing.
They aren't hard to replace, but can be a pain sometimes. Just make sure you don't drop the cap and lose any of the needle bearings when you put the new one in. The grease does a pretty good job of holding it all together but just be mindful.
This is what a bad U-joint will look like if you have play in it:
Now, this guys U-joint is REALLY bad. Yours may not be this bad, but any play left/right up/down is bad. This play is different from rotational slop that can also be felt if you turn the driveshaft and you hear a click because of the rear end stopping it. Strictly look for play in the joint
That’s a great video Mike.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Well - looks like I bent the LH spindle for sure - as the tie rod end is angled - not vertical like the RH side - didn't see it until tonight. I'll pull the wheel this weekend - but I'm thinking it's scraping the back side of my aluminum rim.
It didn't make sense that it that DS universal failed but it sure sounded like it coming from the DS tunnel. The grinding started as soon as I hit the rut (torn up asphalt that runs all the way across the road) - which keeps getting worse.Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
Raven
That was one helluva dip! You are sure you bent the spindle and it isn’t the damaged tie-rod making it look off?
That sucks Robert, not too long ago didn’t you have to replace a spindle? Because it was bent.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Yes - used of course - found that the LH side was bent, alignment was maxed out. Now the RH side - but I've had a spare set for years. Used the LH 2 years - now I'll use the RH - just hope the lower A-arm is OK - I'll see this weekend.Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
Raven
Originally posted by LETZRIDE View PostThat was one helluva dip! You are sure you bent the spindle and it isn’t the damaged tie-rod making it look off?Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
Raven
Originally posted by FirebirdGT View PostYes - used of course - found that the LH side was bent, alignment was maxed out. Now the RH side - but I've had a spare set for years. Used the LH 2 years - now I'll use the RH - just hope the lower A-arm is OK - I'll see this weekend.
If I need to replace the A-arm - need to blast, power coat, new bushings, and ball joint - and pay to have it all done. I might just get the UMI boxed lower A-arms and be done with it.Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
Raven
My lower A arms from PA racing broke at the weld- the UMI boxed ones look like a much better design and I may one day run them as well.
IIRC- the bolts to remove the A-arm will be seized pretty bad. Actually I don’t think I ever got mine out ( mind you this was before I had a good air gun and a map torch)
You may want to order new bolts just in case. I remember I broke every bolt getting my subframe off and spent days drilling them out (I bet if I had to use a torch and an airgun I would not have though! Experience!)
Originally posted by FirebirdGT View PostIf I need to replace the A-arm - need to blast, power coat, new bushings, and ball joint - and pay to have it all done. I might just get the UMI boxed lower A-arms and be done with it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411Well my iPhone 11 Pro Max took a dump, it’s in a boot up loop, will try and get it fixed and give it to my mom. So I got a new iPhone 15 pro max, everything...1 week ago
by ssms5411So I’m still leaking coolant, I think it’s my front cover, going to double check when it’s alittle warmer, got the Zzp extra thick timing cover...2 weeks ago
by transamtom1Local car on a small lot just over 100k mikes(178,000 kms)
Silver with grey leather and black top 3.8L for $5400 cdn or $3975 usd as is....3 weeks ago
