I want to replace it with reflective ones. How I remove it without scratching it off.
How do I delete this tail light emblem
Is there a spray remover that you can use? I have also read a lot of people saying they go their hands on a pinstripe/decal remover spray that body shops use- may be worth investigating- I agree in the video it didn’t look as shiny as it originally was...
- 1 like
Originally posted by LETZRIDE View Post
I found this video, but it seems pretty intrusive...
Only Formulas had blank center panels - that's what I have - so I was able to put the decals I wanted on it without any issues.
There was someone cleaning, polishing and installing decals on the panel on eBay in the past.
My logo is my center panel.
Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
Raven
- 1 like
I've removed my decal with sandpaper! I think I used around 600 grit and worked my way up to 2000 or 2500. I then used a few polishes. Believe i started with a rubbing compound then scratch-x and then plastix. I kept shifting between these polishes and eventually used a clay bar, meguiars #7 and then topped with wax. It's been over 5 years and it looks great! Can use the same process if/when the filler gets a white oxidation build-up.
- 1 like
I came across this site and it reminded me of your post. They have reflective options that you could possible simple adhere over your originals. Just a thought.
https://www.pfyc.com/FB1005.html
I have never used them or the site, just a bit of info I fell over. :)
- 1 like
What about using black vinyl wrap over the top of the existing panel and adding your preferred design over that? If it ended up looking a bit crap you'd be able to just peel it off with no permanent damage done.. a sample roll (5' x 12") can be had for under $10 on Amazon, I think.
I have some sun damaged clear coat between my T-tops and the rear screen and am thinking about using black wrap to hide it.
Anyone's thoughts or experience with wrap would be greatly appreciated.
- 1 like
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...2 weeks ago
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...3 weeks ago
