Engine Part Numbers Post - FirebirdV6.com/CamaroV6.com Message Board
This is a sticky topic.
  • Engine Part Numbers Post
    CONTRIBUTORS TO THIS LIST:
    AZ3.8Camaro
    98Camaro3.8
    viper04af
    pgriffith
    grayman
    Ironman24
    THANK YOU!!!
    -=Prices are from GMpartsdirect.com=-
    Head gasket sets: (Includes: Head gaskets, intake gaskets, valve cover gaskets, o-rings)
    Design 1 (usually 95-97) has blue lower intake manifold gasket without locating pins.
    GM # 12537615
    Price: $51.01
    Design 2 (usually 98+) has orange lower intake gaskets with locating pins.
    GM # 12539095
    Price: $66.85
    Head set (98+):
    GM # 89017404
    Intake set (98+):
    GM # 12480831
    -=ALL YEARS=-
    Head gaskets:
    Right Side
    GM # 24503801
    Price: $26.39
    Left Side
    GM # 24503802
    Price: $17.32
    Front timing cover gasket:
    GM # 024502252
    Price: ?
    Valve cover gasket:
    GM # 025532619
    Price: ?
    Timing Chain:
    GM # 24504668
    Price: $38.18
    Cam Sprocket:
    GM # 24505306
    Price: $30.96
    Crank Sprocket:
    GM # 24502431
    Price: $26.97
    Timing Chain Tensioner:
    GM # 10189283 OLD
    GM # 24503893 NEW (Got new number, same part.)
    Price:
    Valve Stem Seals:
    Exhaust:
    GM # 088891775
    Price:
    Intake:
    GM # 88891774
    Price: $3.52 (Sold in pack of 5 only).
    LS1 valve spring retainers:
    GM # 10166344
    Price: $1.40 each (sold in packs of 4)
    Heater Bypass Inlet Pipe
    GM # 24503423
    Lower Thermostat Bypass Pipe
    12565082
    Lower Thermostat Bypass Seal
    GM # 25537068. 2 needed, comes in pack of 10.
    Fuel Injector Seal Kit
    95-99: GM # 17113544
    00-02: GM # 17113400
    Camshaft Thrust Plate Bolts
    Very easy to strip these.
    GM # 25519242. 2 needed, comes in pack of 10
    Camshaft Sprocket Bolt
    GM # 24501366
    Crank bolt
    95-97: GM # 24504736
    97-02: GM # 24506341
    97 listed twice, don't know why.
    Rocker Arm Bolts
    GM # 24503515. 12 needed, comes in pack of 5.
    Intake Air Temp (IAT) sensor grommet:
    GM # 24504388
    Stock L36 Camshaft:
    GM # 24505811
    Upper intake gasket (98)+:
    GM # 24504789
    Lower intake gasket (98+):
    GM # 12480831
    Upper and Lower intake gasket set (95-97):
    GM # 12537616
    Thermostat gasket:
    GM # 24502433
    Throttle body gasket:
    GM # 24503432
    Rear main seal:
    GM # 25534760
    Rear engine cover seal:
    GM # 24507388
    Oil Pickup tube gasket:
    GM # 24501259
    Oil Pan gasket:
    24502397
    If you are doing a head and cam swap, you need:
    Head gasket set (design 1 or 2)
    Recommended extras:
    Timing chain, Sprockets, Tensioner, Valve stem seals. Maybe a water pump gasket from a local shop.
    Thats enough for now, I need the PNs for the cam swap gasket set that doesn't include the head gaskets.
    Don't ask why one head gasket costs more than the other, or why valve stem seals are sold in packs of 5, and not 3 or 4.
    [ November 09, 2005, 04:24 AM: Message edited by: AZ3.8Camaro ]
    1997 Dodge Viper GTS
    Re: Factory Part Numbers
    Originally posted by AZ3.8Camaro
    Intake set (98+):
    GM # 12480831
    [ [ November 09, 2005, 04:24 AM: Message edited by: AZ3.8Camaro ]
    This has been superceeded by #89017402
      GM # 12539095
      Price: $66.85
      Part # not found on GMPartsdirect.com
        GM # 024502252
        Price: ?
        Correct # 24502252
        GM List $8.42
          Valve cover gasket:
          GM # 025532619
          Price: ?
          Correct #25532619
          GM List $20.70
            12539095 has been repalced twice new number is 89017821 $130.42
            96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
              89017861 New 3800 Long Block
              24508594 Tensioner 98+ LIST $146.81
              24504818 Tensioner 97- LIST $142.02
              12192355 Ac Delco Plug Wires $52.02
              24503423 Pipe (everyone Breaks It While Changing Tensioner)$9.71
              12563241 Oil Pan$168.47
              89060462 Water Pump$126.04
              3800 Engine Parts
                AZ3.8Camaro
                98Camaro3.8
                viper04af
                pgriffith
                grayman
                Ironman24
                THANK YOU!!!
                GM # 12537615
                Price: $51.01
                superceeded by 89017820 and discontinued
                  AZ3.8Camaro
                  98Camaro3.8
                  viper04af
                  pgriffith
                  grayman
                  Ironman24
                  THANK YOU!!!
                  GM # 12537615
                  Price: $93.05
                  GM # 89017404
                  Price: $130.42
                  Head set (98+):
                  GM # 89017404
                  Intake set (98+):
                  GM # 12480831 $51.99
                  -=ALL YEARS=-
                  Head gaskets:
                  Right Side
                  GM # 24503801
                  Price: $52.00
                  Left Side
                  GM # 24503802
                  Price: $33.77
                  GM # 12587003
                  Price: $8.65
                  Valve cover gasket:
                  GM # 25532619
                  Price: $20.70
                  Timing Chain:
                  GM # 24504668
                  Price: $75.14
                  Cam Sprocket:
                  GM # 24505306
                  Price: $60.98
                  Crank Sprocket:
                  GM # 24502431
                  Price: $18.65
                  GM # 24503893
                  Price:$27.86
                  Valve Stem Seals:
                  Exhaust:
                  GM # 88891775
                  Price:$7.09
                  Intake:
                  GM # 88891774
                  Price: $6.75 EACH(sold in pack of 5 only).
                  GM # 10166344
                  Price: $2.63 each (sold in packs of 4)
                  GM # 24503423
                  PRICE: $9.71
                  12565082 PRICE$3.25
                  GM # 25537068. $1.09 EACH 2 needed, comes in pack of 10.
                  95-99: GM # 17113544 $23.96
                  00-02: GM # 12570621 $15.89
                  GM # 25519242. $1.18 2 needed, comes in pack of 10
                  GM # 24501366 $5.55
                  Crank bolt
                  95-97: GM # 24504736 $10.37
                  97-02: GM # 24506341 $18.12
                  Rocker Arm Bolts
                  GM # 24503515.$1.39 12 needed, comes in pack of 5.
                  GM # 24504388$2.79
                  Stock L36 Camshaft:
                  GM # 24505811 $394.67
                  GM # 24504789 $19.93
                  GM # 12537616 $49.05
                  Thermostat gasket:
                  GM # 24502433 $2.15
                  GM # 24503432 $7.72
                  Rear main seal:
                  GM # 25534760 $17.34
                  GM # 24507388 $4.28
                  GM # 12581570 $1.81
                  Oil Pan gasket:
                  12587964 $54.44
                  Recommended extras:
                  THIS IS UPDATED WITH CURRENT PART NO.'S AND GM LIST PRICES
                    Re: Engine Part Numbers Post
                    Thank you!
                      gm part# 25535220- 95-99 $6.50
                      gm part# 10070107- 00+ $9.98
                      COOLANT INLET VENT SCREW.
                        Seems like an appropriate place, for this info...
                        '98-'02 3.8 V6 Harmonic Balancer (Crank Pulley) PN# 12563281- $163.81
                        gmpartsdirect.com lists it for - $96.88
                        I've got dreams bigger than my wallet can handle. :work:
                          http://www.gvperformance.com/9302camaromanuals.pdf
                          link to parts manual, thanx 97rs
                            Originally posted by david8399
                            yea no problem. :)
                            http://www.bowtiev6.com/
                              Just replaced my oil pan...
                              3.4l V6 oil pan
                              GM# 10115790
                              Price: $96.91
                              • Andy H
                                Hello everyone!
                                by Andy H
                              • 3.4 slow to go
                                hey there strangers!
                                by 3.4 slow to go
