Hi All I want to install an Autometer sport comp tach. I'm at a loss on where to run the wires....
Installing a Autometer Tach Need Help!!!!
I think the shift light is the same wiring, when I was a m5. I took the tach signal from the cam sensor, would have to look up which wire but theres only 3. I remember trying it from the pcm to get the signal and the car would die on me so I did the cam wire. Haynes manual has the diagram for which wire to tap into. What is the wiring you need? Power, ground and signal wire correct?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostI think the shift light is the same wiring, when I was a m5. I took the tach signal from the cam sensor, would have to look up which wire but theres only 3. I remember trying it from the pcm to get the signal and the car would die on me so I did the cam wire. Haynes manual has the diagram for which wire to tap into. What is the wiring you need? Power, ground and signal wire correct?Last edited by 6PK...; 09-03-2019, 05:19 PM.
Should be in your instructions. I think Autometer has online instructions as well.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...2 weeks ago
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...2 weeks ago
