2010-2015 V6 Camaro Specifications - FirebirdV6.com/CamaroV6.com Message Board
This is a sticky topic.
  • 2010-2015 V6 Camaro Specifications
    5th Gen Camaro Engine & Model Specifications
    Specification 2010 2011 2012 2013 2014 2015
    V6 Models LS, LT LS, LT LS, LT LS, LT LS, LT LS, LT
    Motor Code LLT V6 LLT V6 LFX LFX LFX LFX
    Fueling Direct Injection - Variable Valve Timing Direct Injection - Variable Valve Timing Direct Injection - Variable Valve Timing Direct Injection - Variable Valve Timing Direct Injection - Variable Valve Timing Direct Injection - Variable Valve Timing
    Configuration DOHC 24 Valve DOHC 24 Valve DOHC 24 Valve DOHC 24 Valve DOHC 24 Valve DOHC 24 Valve
    Displacement 3.6L
    (217 Cu In)
    3.6L
    (217 Cu In)
    3.6L
    (217 Cu In)
    3.6L
    (217 Cu In)
    3.6L
    (217 Cu In)
    3.6L
    (217 Cu In)
    Built In Oshawa, ON Oshawa, ON Oshawa, ON Oshawa, ON Oshawa, ON Oshawa, ON
    Bore 3.7 in 3.7 in 3.7 in 3.7 in 3.7 in 3.7 in
    Stroke 3.37 in 3.37 in 3.37 in 3.37 in 3.37 in 3.37 in
    Engine Block Cast aluminum with cast in place bore liners Cast aluminum with cast in place bore liners Cast aluminum with cast in place bore liners Cast aluminum with cast in place bore liners Cast aluminum with cast in place bore liners Cast aluminum with cast in place bore liners
    Cylinder Head Aluminum Aluminum Aluminum Aluminum Aluminum Aluminum
    Compression 11:3:1 11:3:1 11:5:1 11:5:1 11:5:1 11:5:1
    Horsepower / Torque 304 Hp 273 Tq 312 Hp 278 Tq 323 Hp 278 Tq 323 Hp 278 Tq 323 Hp 278 Tq 323 Hp 278 Tq
    Max RPM 6700 rpm 6700 rpm 7200 rpm 7200 rpm 7200 rpm 7000 rpm
    Transmission Type 6L50 6 Speed / AY6 Aisin Warner 6 Speed Manual 6L50 6 Speed / AY6 Aisin Warner 6 Speed Manual 6L50 6 Speed / AY6 Aisin Warner 6 Speed Manual 6L50 6 Speed / AY6 Aisin Warner 6 Speed Manual 6L50 6 Speed / AY6 Aisin Warner 6 Speed Manual 6L50 6 Speed / AY6 Aisin Warner 6 Speed Manual
    Final Drive 3.27 3.27 2.92 (2LS) / 3.27 2.92 (2LS) / 3.27 2.92 (2LS) / 3.27 2.92 (2LS) / 3.27
    Weight (lbs) 3750 - 3780 3719 - 3902 3719 - 3902 3741 - 3913 3702 - 4002 3702 - 4002
    Mileage (est) 17 City / 26 Hwy 17 City / 29 Hwy 17 City / 30 Hwy 17 City / 30 Hwy 17 City / 30 Hwy 17 City / 30 Hwy
    Fuel Capacity 19 Gal / 72 Litres 19 Gal / 72 Litres 19 Gal / 72 Litres 19 Gal / 72 Litres 19 Gal / 72 Litres 19 Gal / 72 Litres
    Oil Capacity 7.6 QT / 7.2 L 7.6 QT / 7.2 L 7.6 QT / 7.2 L 7.6 QT / 7.2 L 7.6 QT / 7.2 L 7.6 QT / 7.2 L
    Media File Link 2010 V6 Camaro 2011 V6 Camaro 2012 V6 Camaro 2013 V6 Camaro 2014 V6 Camaro 2015 V6 Camaro
    I have created a table for all the 5th Gen Camaro specs as far as the v6 models go.
    If there is other information you want to see included in this table, post it in here and I will look to get things added.
    I want to see about maybe adding 0-60 times as well as 1/4 mile stock times for all the 5th gen cars. I am also probably going to add a link to GM's media file for each year car.
    • Andy H
      Hello everyone!
      by Andy H
      Its been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...
    • 3.4 slow to go
      hey there strangers!
      by 3.4 slow to go
      been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...
