I'm thinking about getting a v6 camaro but i was wondering if it would be possible to get it down to 14seconds in the 1/4 mile? I would like to do it without nitrous of FI. would full exhaust, CAI, 3.42gears, slip differential get me there?
3.8l camaro 14second 1/4 mile?
Re: 3.8l camaro 14second 1/4 mile?
You'll need a bit more to get it to 14 sec., cam , headers free flowing exhaust and weight reduction. Also depends on your DA.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Best 1/8mile pass ive ever made was a 9.786 which is around a 15.2 or so. I have
Air Silencer Delete, Shaved Intake Lid, K&N Air Filter, Eaton Limited slip, UMI Rear LCAs PHB & SFCs, Pacesetter Mid-Tube Headers & Y-Pipe, 3'' full exhaust, !EGR, !CAT, custom street tune which got me about 10-15hp.
Your density altitude will play a big role as well. Like this weekend was cold air and low humidity which leads to good air I ran .2 faster in the 1/8th on street tires compared to my normal drag radials
Originally posted by C0DY1921 View PostI'm thinking about getting a v6 camaro but i was wondering if it would be possible to get it down to 14seconds in the 1/4 mile? I would like to do it without nitrous of FI. would full exhaust, CAI, 3.42gears, slip differential get me there?
2001 Firebird V6 Y87 W68 cloth interior a/c deleted.
You want a quick car get an LS1,not much more money and you start out 2 seconds faster.
Plenty of used mods FS cheap as well.
Originally posted by CFreed11 View PostLETZRIDE's heavily modded 3.8 ran mid-13's
Originally posted by EarlR View PostSo, looking at his car page, it sounds like he has had the heads p&p and shaved a bit, good cam w/beefed up valve train, slightly larger injectors, intake/exhaust, 4.10 rear, and a good tune? Is that pretty much the recipe for a 13 sec V6 (assuming 0 DA)?
Headers/ exhaust, stall, gears, HP tunners and light wheels will get you very close. I run 14.40 without the nitrous. Bone stock engine other than the Yella Terra 1.9 roller rockers. 0 weight reduction.Last edited by bigbrian442; 10-28-2013, 09:00 PM.sigpic
Originally posted by Docta View PostAnd quite a bit of weight reduction.
LNorton has run low 12's all motor with stock heads...damn eliminator class guys! They know all the secrets...
Originally posted by LETZRIDE View PostI wouldn't say quite a bit, I was 3100lbs, there was still lots more to come out :P
I keep going back and forth about whether to go any further with the engine in my car, or just start looking for a wrecked SS or Z28 to grab the drivetrain from. If I could get it where it was capable of running 14-flats without having to do a race build I would probably stick with what I have.
http://highperformancejunkies.com/about-me-racing/ thats all the mods that LETZRIDE has if you were wondering. I happened to run into this YouTube channel and he had that page linked
Originally posted by EarlR View PostIs that 3100 with driver? I think the last time I went across scales my car was just shy of 3600, with my large (260 lb) backside in the seat.
by ssms5411Well my iPhone 11 Pro Max took a dump, it’s in a boot up loop, will try and get it fixed and give it to my mom. So I got a new iPhone 15 pro max, everything...1 week ago
by ssms5411So I’m still leaking coolant, I think it’s my front cover, going to double check when it’s alittle warmer, got the Zzp extra thick timing cover...2 weeks ago
by transamtom1Local car on a small lot just over 100k mikes(178,000 kms)
Silver with grey leather and black top 3.8L for $5400 cdn or $3975 usd as is....3 weeks ago
